Activity Forums Adobe Illustrator illustrator – stroke doesn’t connect / brush pattern
  • illustrator – stroke doesn’t connect / brush pattern
    Posted by Peter James on December 19, 2014 at 5:12 pm
    Hello,
    so I’m having problems figuring out a stroke issue. Below is an image of what I am referring to.
    Essentially, I want to create a brush that I can use on strokes so that no matter the shape, when I use it, I have 3 horizontal lines applied as the stroke.
    At the moment, if I use the pattern brush, the outer corners are all over the place. If I use the art brush, the ends do not connect.
    What can I do?
    Peter James replied 11 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
