Activity Forums Adobe After Effects Illustrator shapes into after effects?
  • Illustrator shapes into after effects?
    Posted by Peter Stenhouse on July 15, 2005 at 10:29 am
    Hi there. I was hoping to bring in IllustratorCS shapes into After effects either as masks or as motion paths. I have tried copying and pasting the selected path from illustrator into the position field of null or an effect and it doesn’t seem to work. What am i doing wrong? Vector layer masks seem to import from Pshop, but I can only get rasterized stuff from illustrator.
    Thanks for your help
    Peter
    Adam Bennett replied 21 years, 2 months ago 3 Members · 2 Replies
  • Mylenium
    July 15, 2005 at 11:04 am
    Are you sure you have set your clipboard format in illustrator correctly? It should be the ADB-something, not PDF compliant.
    Mylenium
    [Pour Myl
  • Adam Bennett
    July 15, 2005 at 11:16 am
    Go to Preferences > Files & clipboard and make sure PDF and AICB is checked in the copy settings. Then make a new solid and your shape should paste as a mask
