Illustrator shape morphing.
So, I created 2 shapes ( outline + fill ) in separated files in AI and imported them in AE (test1.ai & test2.ai). After that I created shapes from the vector layer for each of them. I created a Path keyframe for each, for test1 keyframe on 1st sec, same for test2. I copied test2 keyframe and pasted on the 2nd second on test1, then I deleted test2. When I play the project, I get this – https://gyazo.com/050f57b27f56aea67ab873f978f5b0c7 . Here is my problem: these shapes should be an eye (part of it), and the morph I get is too weird to let it like this. How can I morph them to be like regular eye morph, if you understand what I want to create. Thanks in advance!
