Activity › Forums › Adobe Illustrator › Illustrator – relevel rotated text
  • Illustrator – relevel rotated text
    Posted by Vincent Rosati on October 25, 2006 at 8:26 pm
    I have an AI file with numerous instances of rotated point type. Is there any way to return this type to it’s original horizontal orientation – other than manually rotating each instance?
    Mike Gondek replied 19 years, 11 months ago 2 Members · 1 Reply
  • Mike Gondek
    November 3, 2006 at 8:25 pm
    No there is not, Illustrator does not keep track of the original attributes before transformation as a page layout program like InDesign or Quark does.
    Can you set a new point text with all the characters you need?
    If all the type are different fonts I would set a line of point type in arial, then select each letter by characters, and use the eyedropper to sample the character attributes (size/color/font/etc). You may want to doubleclick the eyedropper prior to this and check to pick up appearance attributes also.
