Activity › Forums › Adobe After Effects › Illustrator Project has problems when trying to be animated in AE.
Posted by Leo Yañez on August 10, 2018 at 2:29 amGreetings! ????
I have some problems at the moment of creating shapes from vector layer. The AE project screen fills completely with a color of an object inside the project or the
M letter of the project appears invisible.
Appreciate the help! ????
Kalleheikki Kannisto replied 8 years, 1 month ago 3 Members · 6 Replies -
Steve Bentley
August 10, 2018 at 7:02 amThis could be so many things.
A layer that was turned off so you didn’t see it in AI may come into AE and be turned on, especially if its a background that spans the whole comp.It could be a compound mask or clipping mask not being interpreted correctly thereby showing you the AI mask instead of whats inside the mask.
It could be a counter inside a letter not being “see through” and instead become a solid. So if you had a large “O”‘ acting like a window, all you might see is a solid the color of the “O” and that might cover everything behind it.
It could be just the way you have layered your AI project, or the version of AI file vs the version of AE file. I find if you bring a newer Ai file into an older AE file, often groups are broken up into their sub components and each of one those becomes a layer (similar to opening a new AI file in a old version of AI.
Without seeing the original illustrator file it’s hard to say.
No all that being said, the title of the post is what I responded to above, but if you are copying the paths to shapelayers then it might be something else. Check that paths are closed or open as they were in illustrator. I’ve seen lots of paths come in closed where they were open in illustrator.
Leo Yañez
August 10, 2018 at 4:37 pmThanks For the response! ????
I Checked the Ai Project and all the layers are fine, there are no disabled layers nor clipping masks.
I opened the project in AE again, and when I just turn one layer from, “create shapes from vector layer, the random color screens happens.
Leo Yañez
August 11, 2018 at 11:43 pm -
August 12, 2018 at 8:50 amIt sounds like you’ve got some fills with clipping paths there. Did you source the Illustrator file from a PDF perhaps? That could create such.
Senior Graphic Designer -
August 13, 2018 at 3:55 pmYes, if you used Photoshop shape layers, you get this result.
