Activity Forums Maxon Cinema 4D Illustrator Path Imports
  • Illustrator Path Imports
    Posted by Steve Johnson on August 28, 2007 at 12:16 am
    Hi, I have a quick question about the extrude nurb’s object. I can’t seem to get it to do anything withought the “hierarchial” option checked. Mainly Im using it to extrude some text to give a blocky look. Is there a way to use the extrude nurbs w/o hierarchial selected? It doesn’t seeem to do anything w/o it for me.
    Steve Johnson replied 19 years ago 2 Members · 2 Replies
  • Brian Jones
    August 28, 2007 at 12:54 am
    If you put a hierarchical (null with children usually) object in the extrude it needs Hierarchical checked to work. Try putting just a single spline into the Extrude.
  • Steve Johnson
    August 28, 2007 at 1:09 am
    Ahh.. That sheds light on so many things… haha..
    thanks.
