Activity › Forums › Adobe After Effects › Illustrator issues
  • Illustrator issues
    Posted by Astanin on May 9, 2007 at 3:15 am
    i have after effects and illustrator well i took a picture and opened it in illustrator i used livetrace then i copy and try to paste in after effects it won’t let me i did enable aicb and preserve paths is selected under it . i have illustrator cs2 and after effecs v 7.0 any help would be greatly appreciated
    Kevin Camp replied 19 years, 4 months ago 2 Members · 2 Replies
  • Kevin Camp
    May 9, 2007 at 2:46 pm
    make sure that you only have the vector data selected (not the picture you traced) when you copy. that may be the problem.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Kevin Camp
    May 9, 2007 at 2:48 pm
    also make sure you are pasting into a solid in ae… the vector paths from illustrator will need to be pasted as a mask(s) within a solid.
    Kevin Camp
