Activity Forums Adobe After Effects illustrator import
  • illustrator import
    Posted by Mark Joseph on May 24, 2007 at 6:49 pm
    Hello, why is it when I import ai files , I get only
    one file flattened out , this does not happen when I import photoshop
    files… any suggestion as to how I can keep my individual layers in ae 7.0?
    Jason Smart replied 19 years, 3 months ago 2 Members · 1 Reply
  • Jason Smart
    May 24, 2007 at 7:13 pm
    you have to choose import layers when you import your file instead of merged layers. you hit import, then choose your file, then it will give you an option of whether or not you want to import the file as merged layers (all layers are 1 image) or individual layers. you can select the layers you want to use. if that doesn’t work, try looking at your file in Illustrator and make sure that the layers are not merged or grouped there.
    hope that helps.
