Activity › Forums › Adobe After Effects › Illustrator import with transparency.
  • Illustrator import with transparency.
    Posted by Wim ja Bruyninckx on April 21, 2009 at 6:21 pm
    Hi, just a fact that i want to share
    When importing illustrator files that exceeds the crop area, and contains transparency/graphic styles, into AE CS4, usingcomposition – crop layers, layers in AE will be cropped around the image border…
    The fix is saving the footage to illustrator 10 legacy… then it will work as expected…
    Wim ja Bruyninckx replied 17 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
