Activity Forums Adobe After Effects Illustrator images
  • Illustrator images
    Posted by Scott59 on June 7, 2007 at 1:46 pm
    How do I save/export artwork created in Illustrator for use in After Effects Comp without the background. Can i create alpha channel in AI or key out background in AE?
    Kevin Camp replied 19 years, 3 months ago 2 Members · 1 Reply
  • Kevin Camp
    June 7, 2007 at 2:01 pm
    if your ai artwork is not on a background (a rectangle with a fill color or something) then when you bring it into ae the non-vector areas should be transparent.
    how are you saving your illustrator files?
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
