Activity Forums Adobe Illustrator Illustrator Help
  • Illustrator Help
    Posted by Bena911 on February 23, 2006 at 6:40 am
    A client has sent me CS ai files and I only have version 10. Is there any applications out there other than CS that will let me open these and save them dowm to v10?
    thanks
    Ben
    Jeff Kelley replied 20 years, 6 months ago 2 Members · 1 Reply
  • Jeff Kelley
    February 23, 2006 at 3:13 pm
    You could ask your client to down save it for you. (File/Export/Legacy) That’s your best bet. You might be able to open it in Acrobat, I’m not sure. If you are sure you don’t have to make changes you could also open it in PhotoShop, just make sure you res is high enough. I’d recommend 300 dpi if it’s only pics, and 1200 dpi if there is a lot of text.(600 dpi minimum. Of course I’m talking about for print.
