Activity Forums Adobe After Effects Illustrator file updates not reloading correctly in After Effects CS5.5
  • Illustrator file updates not reloading correctly in After Effects CS5.5
    Posted by Liz Scherer on May 12, 2011 at 12:34 pm
    When using CS5 I was able to insert new layers in my Illustrator document without causing a problem with After Effects. I could just load the new layer, re-load any other layers where I had made changes and all was well.
    Now I have CS5.5 and inserting a layer into Illustrator anywhere except at the top will cause After Effects to display the contents of another layer, cropped to the size of the correct layer. Reloading does nothing. I have to go, and one by one, painstakingly replace footage with each layer above where I had made the change in Illustrator. Same layer name and all, but replacing footage works, reloading doesn’t.
    I have an AI file with about 100 layers on one artboard, after having issues with separate artboards in AE.
    Suggestions?
    Liz
    Liz Scherer replied 15 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
