Activity Forums Adobe Illustrator Illustrator – ‘document size’ vs ‘displayed size’
  • Illustrator – ‘document size’ vs ‘displayed size’
    Posted by Gunnar Kordestani on December 18, 2007 at 4:37 am
    it’s a simple one and if there would be a ‘Read First’ I would have checked it….
    if I have an illustrator document in let’s say 120mm X 90mm. Why is the displayed size (100%) so much smaller and do I have to worry about that?
    Maybe it’s just an Scrren Resolution issue, or so?
    I want to print the designed thing later, so it matters to me.
    thx
    Gunnar
    Vincent Rosati replied 15 years, 8 months ago 4 Members · 3 Replies
  • Richard Harrington
    December 19, 2007 at 2:33 am
    Display size has nothing to do with print size.
    Look at your Docuemnt settings to see print size
    Suggest you get started with the Classroom in a Book and build a solid foundation
  • Gunars Ratnikovs
    January 3, 2011 at 10:51 pm
    hello. I have illustrator print document size 2m x 11m . how can i set it up, when i am trying to do that it keeps me saying that it has to be max 577.xx cm.. help asap! thanks!
  • Vincent Rosati
    January 4, 2011 at 6:02 am
    Make your document 1/2 scale – 100 cm x 550 cm.
    Or smaller, 1/4 scale – 50 cm x 275 cm.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
