Activity Forums Adobe Illustrator Illustrator CS6 – Not Precise
  • Illustrator CS6 – Not Precise
    Posted by Jeremy Wick on July 3, 2012 at 9:31 pm
    I am unable to move or re-size objects in small/detailed amounts. Also, smaller objects are not getting perfectly centered when I align them to the artboard. All the “snap-to” are off. I never noticed an issue with this in CS4. Am I missing something?
    Kenneth Brøgger-luplau replied 12 years, 5 months ago 3 Members · 2 Replies
  • Vincent Rosati
    July 3, 2012 at 11:33 pm
    Maybe check the options menu in the Transform palette and see if you have “Align New Objects to Pixel Grid” checked. I think this was introduced in CS5.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Kenneth Brøgger-luplau
    April 26, 2014 at 11:04 am
    Thank you!!
