Activity Forums Adobe Illustrator Illustrator CS5 (Win7) – Problems when grouping elements and using Isolation mode
  • Illustrator CS5 (Win7) – Problems when grouping elements and using Isolation mode
    Posted by Bertil Oldenburg on August 9, 2012 at 8:45 pm
    Is there a difference in how grouping elements and using isolation mode works in Illustrator CS5 in Mac and Windows?
    I’ve tried it in Windows and the isolation mode only partly works – some element doesn’t group together and other objects (the ones not selected) doesn’t fade when I try to build larger groups (with more than two child groups in one parent group).
    I’ll post more details when/if needed.
    All help is appreciated.
    Kind Regards
    Bertil
    Bertil Oldenburg replied 14 years ago 1 Member · 1 Reply
  • Bertil Oldenburg
    August 12, 2012 at 11:18 pm
    Solved it myself.
    The solution:
    Use the layer pane instead of the selection tool.
    Kind Regards
    Bertil
