Activity Forums Adobe Illustrator Illustrator CS4 quitting when I try to save
  • Vincent Rosati
    April 25, 2010 at 11:18 pm
    I don’t have a straight answer.. but, try saving:
    a blank file
    a file with a shape
    a file with a little text
    It might help to narrow down the issue.
    Maybe try disabling PDF compatibility also.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
