Activity › Forums › Adobe Illustrator › Illustrator CS2 problem: Can’t adjust size and scale
  • Illustrator CS2 problem: Can’t adjust size and scale
    Posted by Randy Steele on February 4, 2010 at 5:28 pm
    I was working on a document recently using Illustrator CS2, and I lost the ability to size or scale images and text.
    The tiny white boxes that usually border the object are gone. Instead, only the blue boxes are there, which, of course, don’t allow such manipulation.
    Unfortunately, this problem has happened to all my Illustrator documents. I can’t grab an image or text block and adjust it’s size or scale on anything.
    Does anyone know what has happened? Adobe refuses to help because CS2 has expired.
    Randy Steele replied 16 years, 8 months ago 2 Members · 2 Replies
  • John Mensinger
    February 4, 2010 at 6:26 pm
    With no files open, choose View > Show Bounding Box
    John M:
    All of the vim with none of that annoying vigor.
  • Randy Steele
    February 4, 2010 at 6:43 pm
    Thank you so so much.
