Activity Forums Adobe Illustrator Illustrator CS – best way to clean crop vector image
  • Illustrator CS – best way to clean crop vector image
    Posted by Reneon on February 4, 2006 at 11:27 am
    I’ve got a complex vector image inside a document and I want to crop it.
    I’ve tried using a clipping mask but it seems like a temporary solution as the unwanted points are still there, albeit out of sight. Can I clean up the clipping mask to make the effect permanent, deleting the paths cleanly underneath?
    Or is there a more efficent method altogether?
    Rene
    Vincent Rosati replied 16 years, 10 months ago 3 Members · 3 Replies
  • Reneon
    February 4, 2006 at 12:08 pm
    Got there using ‘crop’ in the pathfinder palette!
  • Tabitha Moore
    December 1, 2009 at 10:36 am
    I’d like to know the answer to this too. Anyone know?
    Thanks.
  • Vincent Rosati
    December 1, 2009 at 12:15 pm
    I’d vote for a clipping mask and setting the document size appropriately.
    It’s a balance judgment, based on the the time it would take to optimize a vector and working with a complex illustration that uses numerous nesting techniques – like masks, etc.
    Otherwise, as Rene offered, the tools in the pathfinder palette would be my next option.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
