Activity Forums Adobe Illustrator Illustrator CC 2014 – how to remove / change transparency
  • Illustrator CC 2014 – how to remove / change transparency
    Posted by Scott Roberts on November 26, 2014 at 1:07 am
    I noticed that after setting an objects transparency to 60%, then trimming it using another object using pathfinder minus front, it’s transparency changes to 100% in the transparency panel, but it still appears as if it’s 60%. So, if I want the object to then appear as having NO transparency, I’m unable to find a setting or tool to do that since it already says 100% in the transparency panel.
    Any ideas?
    Thanks in advance,
    Scott
    Portfolio
    César Vizarreta pizarro replied 11 years, 2 months ago 3 Members · 3 Replies
  • Jonathan Ziegler
    November 26, 2014 at 2:56 pm
    Illustrator can be tricky at times. Make sure the correct object is selected (make sure you have the fill not the stroke – that kind of thing). To be absolutely sure, check the Appearances palette to be sure the right bits are set to the right opacity.
    Save early. Save often.
    Jonathan Ziegler
    http://www.electrictiger.com
    520-360-8293
  • Scott Roberts
    November 27, 2014 at 5:31 am
    Hi! Thanks for your reply. It occurs if I have a compound path made up of two or more objects with transparency, then trimming those objects – they no longer reflect a 60% value for transparency, but 100%. The object appears to have transparency, however it’s value is 100%, so it can never go back to being 100% opaque.
    Portfolio
  • César Vizarreta pizarro
    July 17, 2015 at 7:55 pm
    Hi Scott Roberts, I read your problem because I had the same one. And I found the solution (If you have not found the solution). On the layer with the object you had with transparency, go to its sublayer, and then aplay transparency to THAT sublayer, and you will find the original transparency value you edited before. Hope it helps you and everyone who have the same problem
    Regards!
