Activity Forums Adobe Illustrator Illustrator can’t open file
  • Illustrator can’t open file
    Posted by Scott Adams on May 2, 2010 at 4:23 pm
    For the past few days I have been working on a project in illustrator CS4. As of about midnite last night I can’t open it anymore. I get the following error:
    Can’t open the illustration. The illustration contains an illegal or misplaced operator.
    Offending operator ‘+’
    Context:
    %+VdL+
    Les Nemeth replied 16 years, 4 months ago 2 Members · 1 Reply
  • Les Nemeth
    May 3, 2010 at 4:10 am
    If you’re lucky and saved the file as a PDF compatible file (by default), you can try to open it in Acrobat then re-save it. However, if you re-save it, all AI specific features will be lost and you will only have the plain vector work.
    You could try opening it in CS5 (download a trial), or you could reinstall AI.
    These are the tips I have. If none of them helps, at least you get some hardcore experience to re-create the whole thing. (That’s my idea of having fun…)
