Activity Forums Maxon Cinema 4D Illustrator > C4D Spline Importing Issue
  • Illustrator > C4D Spline Importing Issue
    Posted by Christian Robinson on December 20, 2015 at 7:01 am
    Hi All,
    So as you can see, I’m having some trouble with a path import between Adobe Illustrator and C4D, and I’m curious if you guys have any ideas of how to fix this problem? Thanks for all your help over the past year, by the way, this is my first post and I’m a newbie to most of this stuff but have created my first animations with the help of this community! Much love! 🙂
    Best,
    Christian
    Enrique Rovira replied 10 years, 8 months ago 3 Members · 4 Replies
  • Brian Jones
    December 21, 2015 at 2:56 am
    what version of C4D? (might not make a difference) – Probably would have to see the illustrator file to see what it does.
  • Christian Robinson
    January 1, 2016 at 12:13 am
    Hey sorry, I didn’t see your response. thank you! I’m using cinema 4d student R17.048, and here’s the illustrator file:
    9609_chakrabranchcopy.ai.zip
  • Brian Jones
    January 1, 2016 at 6:40 am
    interesting, seriously goofed file. It’s an ascii ai try exporting as binary (version 8, of course). I don’t have Illustrator anymore but I opened it in Affinity Designer and it looks ok there and if I export as an eps (designer doesn’t do ai export) that eps opens fine in c4d.
  • Enrique Rovira
    January 2, 2016 at 11:54 am
    Just delete the stroke and save as Illustrator 8 I have just tried it and it solved the problem
