Activity Forums Zaxwerks Illustrator and Invigorator
  • Illustrator and Invigorator
    Posted by Rdub on August 31, 2010 at 6:19 pm
    I have an image created in Illustrator CS 5. When I open it in Invigorator in only opens a part of the image. The part of the image that is not opening is “filled” with gradient mesh. Any idea what might be happening?
    Rdub replied 15 years, 12 months ago 2 Members · 2 Replies
  • Edward Wu
    August 31, 2010 at 8:12 pm
    Hi Bill,
    Gradient Mesh is not supported in 3D Invigorator Pro. This is why the gradient mesh is not showing up when you try to import it into 3D Invigorator Pro. If you convert the Gradient Mesh shape into a normal vector path, you should be able to import it into 3D Invigorator Pro without any issues.
    Best,
    Edward
  • Rdub
    August 31, 2010 at 9:11 pm
    Will do. Thank you.
