Activity › Forums › Maxon Cinema 4D › Illuminate unlit areas of a geometry (no backlight)
  • Illuminate unlit areas of a geometry (no backlight)
    Posted by Caio Alves on April 13, 2019 at 12:19 am
    Hi guys. I’ve been trying to learn C4D for the past days (I was using 3ds Max before).
    I’m creating Earth and I want to add a Luminance layer that contains a bitmap with the city lights. However, I don’t this lights to show on the illuminated part of the planet. That’s why I added a backlight shader.
    Unfortunately, I can’t control how much the lights intersect the illuminated area. The backlight shader stops and I get a black line between the illuminated area and the backlight shader.
    Any ideia on how I can achieve this effect?
    Photographer
    Aspiring VFX and 3D Artist
    Caio Alves replied 7 years, 5 months ago 3 Members · 2 Replies
  • Brian Jones
    April 13, 2019 at 9:04 pm
    put the night lights image into a layer with the Backlight shader set to multiply (or whatever works best).
    13263_earthnightlights.c4d.zip
  • Caio Alves
    April 16, 2019 at 6:03 pm
    Thank you for your help!
    I was doing that, but the problem is: I want the night lights to overlap the diffuse map. Cause if they don’t overlap, the transition between then looks kinda bad.
