Activity Forums VEGAS Pro I’ll share my rendering solutions
  • I’ll share my rendering solutions
    Posted by Philippe Orlando on July 16, 2009 at 1:24 am
    I’ve been having a lot of problems lately editing a not too complicated 76 minutes time line in Vegas 7e.
    I just couldn’t render expect to DVD, but I couldn’t render the whole line to the latest version of the cineform codec I’m using, which is the last version available of NEO HDV.
    I finally found a solution.
    I cut the piece in 10 smaller pieces by adding markers. I only rendered between two markers to the highest quality of the Cineform codec, which was FILM SCAN 2.
    When I had my 10 pieces I put them together in a new time line and I rendered again to to film scan. I compare my end results with my original footage and I simply can’t see a difference. I’ve at full 1440 x1080 rez. That Cineform Codec is amazing!
    I also found out that Windows XP dumbs memory and accumulate errors pretty quickly. Rebooting after every 3 renderings made the whole thing a breeze.
    I know, ideally I need to switch to an I7 64 bit system, but I couldn’t in the middle of this project. I will soon
    Also, I had a couple of clips taken from the net and they all needed to be pre-rendered into the Cineform codec.
    If it can help another beginner.
    Phil
    Philippe Orlando replied 17 years, 2 months ago 1 Member · 1 Reply
  • Philippe Orlando
    July 16, 2009 at 4:49 pm
    I also set the Dynamic RAM Preview to 128 MB. and the Maximum # of Rendering Threads to 1
