Activity Forums Apple Final Cut Pro Legacy I’ll go for Kona 2 for FCP – (Nick, Walter – I need u guys)
  • I’ll go for Kona 2 for FCP – (Nick, Walter – I need u guys)
    Posted by Sachin Verma on June 23, 2005 at 3:16 pm
    Thanks for guiding me but still I need some more clear picture. As you should know, I handle all kind of editing jobs in my studio like I need to capture from various sources like SDI, Component, Composite & DV also to meet all the demands of clients.
    The equipment I’ve in studio are:
    * Digital Beta Recorder
    * Beta SP Recorder
    * DV-CAM Recorder
    * Canopus SDI-DV(vice-versa) convertor
    * NTSC-PAL & PAL-NTSC COVERTOR with S-video,composite IN and OUT
    If I go for AGA Cona 2 with the K-box, will I be able to In/Out all of the above signals? If not what else I need to have other than Kona 2 & K-box? Or is this AGA IO to LA there to fullfill the other IN/OUT connections? If yes how much will this IO to LA cost?
    Currently I’m working mostly on SD only but in near future I’ve to work on HD based projects also.
    Please once again write me the list of things I should buy for this whole solution.
    Regards,
    sachin
    Sachin Verma replied 21 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
