Activity › Forums › Web Design (WordPress, Joomla, etc.) › IIS ASP not working
  • Posted by Mike Gondek on December 20, 2007 at 8:09 pm
    I tried to install IIS on a fresh windows install updated with windowsupdate an get the same result on 2 computers. it installs fine but there appears to be a directory security rightd issue.
    I type in https://127.0.0.1 in IE, and I get prompted for a username & password. Since there should be no uisername an password i say ok to blank fields and nothing happens. I finally hit cancel and can see taht it wants to go the loalstart.asp, but errors out with:
    HTTP 401.2 – Unauthorized: Logon failed due to server configuration
    Internet Information Services
    I can preview non-asp pages fine.
    I enable anonymous access in IIS and get
    error ‘8002801c’
    Error accessing the OLE registry.
    /iisHelp/common/500-100.asp, line 17
    I am running IIS 5 which came on my windows disk with MS .NET Framework 3.5 which came from windowsupdate. Do I need to install anything else to get ASP working???????
    Mike Gondek replied 18 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
