Activity Forums DVD Authoring If you put a Pal DVD in the Tower, do you get PAL DVD copies?
  • If you put a Pal DVD in the Tower, do you get PAL DVD copies?
    Posted by Steve Garman on May 15, 2013 at 2:28 am
    I’m guessing the answer to this is obvious, but since I can’t check them I’d just like to be absolutely sure.
    Steve
    Jeff Pulera replied 13 years, 3 months ago 2 Members · 1 Reply
  • Jeff Pulera
    May 15, 2013 at 2:21 pm
    Hi Steve,
    A DVD recorder is neither PAL not NTSC, it just records DATA. Whatever is on the disc will simply be copied.
    Jeff Pulera
    Safe Harbor Computers
