Activity Forums Adobe Premiere Pro If you drop a 29.97 video file into a 23.978 sequence will the info show the actual fps of the clip?
  • If you drop a 29.97 video file into a 23.978 sequence will the info show the actual fps of the clip?
    Posted by Duke Sweden on June 16, 2016 at 12:31 am
    I hope you’re not getting tired of my stupid questions. When I create a new sequence the default is 23.978 fps DSLR. If I drop a clip that the Ninja 2 has recorded in 29.97, the info shows it as 23.976. It also, for some reason, changes the sequence setting from DSLR to Arri. So, does the “Info” panel show the actual fps or the clip or the fps of the sequence? I did notice that I didn’t get the error message about mismatched sequence settings.
    In closing, to put it simply, “Info” panel shows actual clip fps or fps of the sequence setting?
    Never mind. I sold the Ninja 2. More headache than benefit.
    Duke Sweden replied 9 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
