Activity Forums Adobe After Effects Expressions If (true) set value for next 4 frames
  • If (true) set value for next 4 frames
    Posted by Jeremy Wick on November 10, 2021 at 11:50 pm
    Is it possible to make an expression that, when triggered, changes the value for a set amount of frames? For example:
    if (statement == true) {
    // set opacity to 100 for next 4 frames, then 0
    } else {
    0
    Andrei Popa replied 4 years, 9 months ago 2 Members · 1 Reply
  • Andrei Popa
    November 12, 2021 at 6:45 am
    Hi Jeremy. Expressions can’t modify values in other places than the property on which they are applied, for the current frame. But for your case there is a workaround. You can evaluate the statement for the previous 3 frames, and if it’s true, make opacity 100. I imagine your statement checks the value of a property in the project, so you can use .valueAtTime() .
    Something like:
    durationCheck = 4;
    st = false;
    for(i = 0; i<durationCheck; i++){
    if( statement.valueAtTime(time-framesToTime(durationCheck)) == true ) st = true;
    st == true ? 100 : 0;
