Activity › Forums › Apple Final Cut Pro Legacy › Idvd Error message
  • Idvd Error message
    Posted by Vincent Strader on July 15, 2008 at 10:08 pm
    Anybody know what I can do to fix this problem? It’s preventing my burner from burning 🙂 Here’s the message that comes up, even after I delete the Idvd.plist and restart the whole program. Everything works in preview and setting it up, but once I start to burn it gets to step 3. Then at step 4 at multiplexing and burning , the disk ejects and this below message appears.
    Errors Were Found During The Burning Process
    The Recording Device Reported The Media Error
    Power Calibration Area Error (0x73, 0x03.)
    Thanks for any suggestions,
    Vinnie
    Todd Gillespie replied 18 years, 2 months ago 2 Members · 1 Reply
  • Todd Gillespie
    July 21, 2008 at 6:01 pm
    Usually this means that your DVD drive is failing.
    Sometimes you can get by-by using different media.
    But chance’s are you’ll need to replace the burner.
    Good Luck,
    Todd at UCSB
    Television Production
