Activity › Forums › DaVinci Resolve › Identifying color spaces
  • Identifying color spaces
    Posted by Carmelo Casalenuovo on June 7, 2013 at 11:20 pm
    I’m looking for a utility or application that clearly identifies what color space i.e (XYZ,P3, Rec709) my image sequence files are in. Apologies in advance if this not the correct forum, but I felt the it would be the best place to ask.
    Thanks in advance,
    Carmelo
    Juan Salvo replied 13 years, 3 months ago 3 Members · 2 Replies
  • Bill Ravens
    June 7, 2013 at 11:31 pm
  • Juan Salvo
    June 8, 2013 at 1:36 am
    That’s quite cool. But unfortunately it won’t tell you, without identifying metadata embedded, what colorspace your media is in.
    To answer Carmelo’s question. There is no tool that I know of that does this. Something like a dpx sequence is basically a blank slate. Those RGB values could represent anything. The format the media is in can be one indicator however. Don’t see a lot of 4:2:2 P3 material. But basically this is what colorist need to make a concerted effort to track. Naming conventions are a big part of this. And a good eye can usually spot the difference between p3 and 709. And xyz is pretty easy to spot.
    Colorist | Online Editor | Post Super | VFX Artist | BD Author
    https://JuanSalvo.com
