Activity Forums Apple Motion Identical rotations not acting the same
  • Identical rotations not acting the same
    Posted by Jason Twite on June 22, 2009 at 6:40 pm
    Having a little issue working with the rotation parameter under the Transform tab.
    I have the front and back wheel of a forklift each key framed to rotate from zero to -850 degrees across 5 seconds. The back wheel looks to ease in/ease out of the action while the front is a hard start and stop. I’ve gone over every parameter several times and cannot find any differences in the two. I know there’s a “Spin” behavior, but was unable to get equal and desired results.
    Is there an Ease In/Ease Out function I’m looking past here or another parameter problem causing this issue? It’s a simple rotate of two different layers from photoshop, not 3D, nothing crazy.
    Stephen Smith replied 17 years, 3 months ago 2 Members · 3 Replies
