Activity Forums Maxon Cinema 4D Ideas to transform a nonuniform polygons objects to an uniform polygons objects
  • Ideas to transform a nonuniform polygons objects to an uniform polygons objects
    Posted by Din Iulian silviu on March 27, 2019 at 12:13 pm
    Hello everyone.
    I hope that my question to do not be a stupid one…
    I want to transform a nonuniform polygons object to one which is an uniform polygons object. Can this happen?, It is this possible whiteout recreating the object again.
    Here is an example. Originally the object had uniform polygons, but I made this like a demonstration.
    Kind Regards!
    Din Iulian silviu replied 7 years, 5 months ago 2 Members · 4 Replies
  • Brian Jones
    March 30, 2019 at 2:18 pm
    that’s called retopology I think. I haven’t done any but there are some tutorials out there if you search for it. It can be done with C4D native tools and there is at least one plugin dedicated to the task.
  • Din Iulian silviu
    March 31, 2019 at 6:38 pm
    Thank you for your answer!
  • Din Iulian silviu
    April 1, 2019 at 10:36 am
    Is there an command in cinema 4d to un-subdivide like here:
    I can use polygon reduction, but the object loses its uniformity polygons …
  • Din Iulian silviu
    April 18, 2019 at 7:59 am
    After a long search, I finally found what I needed:
    • SUBDIVISION INVERSE > https://code.vonc.fr/?a=41
    I posted here that might be useful to someone…
