Activity Forums Apple Final Cut Pro Legacy Icons read “Media Offline” but the media is there
  • Icons read “Media Offline” but the media is there
    Posted by Joe Taylor on May 6, 2010 at 6:08 pm
    Hello All
    I have a problem that has surfaced before but today I believe I found the cause of the problem but with no easy remedy. It seems that if I open my project in Final Cut Pro with my external source drive shut down, the project will of course open with the media unavailable. When this happens I close the project, boot up my source drive, then reopen my project. However, when the project opens, all my media icons will read with the red “Media Offline.” I can still play and work with the media project, but now all of my icons are gone. I’ve tried reconnecting to see if the icon will return to status with no luck.
    Again, the media is there, its just that the icon is gone. Can anybody offer a quick fix or remedy?
    Thank You,
    Joe Taylor
    Doug Metz replied 15 years, 3 months ago 5 Members · 8 Replies
  • 8 Replies
  • Alex Elkins
    May 6, 2010 at 6:36 pm
    Hi Joe,
    Try deleting the thumbnail cache (you’ll find it in the same folder that your capture scratch resides).
    I’ve not tested this but I’m guessing it would work.
    Alex Elkins
    Salad Daze Films – Freshly Tossed
    Read my blog!
  • Ari Feldman
    May 6, 2010 at 7:01 pm
    Alex is right – this works.
    Ari Feldman
    Editor/Assistant Editor
  • Joe Taylor
    May 7, 2010 at 4:46 am
    Hello Alex and Ari,
    Pardon my naiveté, but would the Thumbnail Cache you’re referring to be the folder(s) that are separate from the bin/folder in the Browser in Final Cut Pro? The reason I ask is that I’m unfamiliar with their being anything other than my media files in these folders.
    Perhaps I was unclear in my original post. The icons that I am missing are the icons in the Browser. Again, the media is there, it’s that Final Cut Pro is telling me the Media is “Off Line.”
  • Ari Feldman
    May 7, 2010 at 5:43 am
    Hey Joe,
    The Thumbnail Cache is located in the Finder in a folder labeled Final Cut Pro Documents.
    Question:
    Are the thumbnails on the clips in your timeline there or are they also showing Offline as well as in your browser?
    When things in FCP go weird I also might trash the preferences.
    Ari Feldman
  • Joe Taylor
    May 7, 2010 at 5:54 am
    Hello Ari,
    After some digging around I found the Cache folder/files that you referred me to and that solved the problem. Thank you so much. Always learning something valuable at Creative Cow.
  • Ari Feldman
    May 7, 2010 at 6:41 am
    Glad to hear it. Keep up the good work.
    Ari Feldman
  • Andy Laviolette
    September 20, 2010 at 3:51 am
    I erased the thumbnail scratch inside the following path and it fixed my problem…
    Users/Documents/Final Cut Pro Documents/Thumbnail Cache Files/
    there were two files and I erased them both while my hard drive was off and disconnected and FCP 7 was shut down. Upon reopening the session everything was back to normal.
    I used to think Mac and FCP would be the end all answer to my crashing problems…nothing is perfect.
    Thanks for the info cow guys!
  • Doug Metz
    May 26, 2011 at 6:44 pm
    Thank you COW-munity!
    Doug Metz
    Anode
