Activity Forums Adobe Premiere Pro Icon view out of order
  • Peter Garaway
    October 16, 2013 at 5:44 pm
    In Premiere Pro CC version 7.0 and later you can sort by ‘List View’. See attached images below.
    Peter Garaway
    Adobe
    Premiere Pro
  • Walter Biscardi
    October 16, 2013 at 5:50 pm
    [Justin Crowell] “Anddddd….apparently no fix in CC. Wonderful.”
    Actually the view order has been completely re-done in CC. Can pretty much put them in any user defined order you like.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author, Chef.
    HD Post and Production
    Biscardi Creative Media
    Southeast Creative Summit, Oct 25-27. Register Now! Save with code: creativecow2013
    Foul Water Fiery Serpent, an original documentary featuring Sigourney Weaver. US & European distribution by American Public Television
    MTWD Entertainment – Developing original content for all media.
    “This American Land” – our new PBS Series.
    “Science Nation” – Three years and counting of Science for the People.
    Blog Twitter Facebook
  • Justin Crowell
    October 17, 2013 at 6:17 pm
    Ah! I wasn’t able to find that. Thanks so much! That will drastically improve my workflow.
    Editor, Producer, DP
    JustinCrowell.com
  • Peter Garaway
    October 17, 2013 at 9:01 pm
    No problem. This was a little but BIG feature.
    Best,
    Peter Garaway
    Adobe
    Premiere Pro
  • Jill Woodward
    December 17, 2013 at 4:34 pm
    Oh this is huge! Maybe having “list view” sort as a default on future versions would save some confusion and headaches for other editors migrating. thanks!
  • William Boodell
    June 18, 2014 at 5:22 am
    I’m trying to set a view in the “sort icons” menu, close the bin and then return to have it still be set to the same view. However, it keeps reseting to some other view, presumably a default. Is there any way to change this behavior? Perhaps there’s a way to set a sort view as default and have it stay that one when you close the bin?
    Also, is there any way to arrange the clips in the order you want in either icon or list view (and naturally have them remain that way once you leave the bin and then return later)? In other words, you lay out the clips in the clip in the order that they would play in your piece. I haven’t seen a way to do this, so my work around is to sort them by using one of the columns such as “Comment” or “Log Note” to provide an order through numbers, letters or both. Is there a simpler way?
    B
  • Jessie Moore
    June 18, 2014 at 2:25 pm
    I’m not sure why the list/icon view is changing when you leave a bin. Someone else might have the answer for that, but sorting by filename is as easy as creating a new bin in premiere – go to finder – click on the “name” tab above your clips in finder, so they are sorted by name, and then drag those clips into the bin.
    The bin will show the clips in the order you bring them in — meaning if you finder sorted by date modified, and drag them in, they will come in by date/time, if you have them sorted by name in finder they will appear in the alpha-numerical order of the filenames.
  • William Boodell
    June 24, 2014 at 4:58 am
    Thank you. We found that it was as simple as using the “User Order” in the “Sort Icons” drop-down menu. This keeps your thumbnail order. You can reorder the thumbnails/clips by clicking, dragging and dropping them where you wish them to be.
    As far as I see, currently the list view order cannot be customized except by using the existing information columns. However one could also use numbers and/or letters in the “Name,” “Comment” or “Log Note” columns (for instance) to be able to maintain a separate order.
    Bill
  • Zoë Davis
    December 5, 2014 at 1:12 pm
    Can List View Sort be set as a default for new projects?
Page 2 of 2
