Activity Forums Adobe Premiere Pro Icon view out of order
  • Icon view out of order
    Posted by Alex Hawkins on July 12, 2011 at 2:40 am
    Hi, does anyone know how to keep a bin full of clips in order when switching from list view to icon view in the project panel?
    Every time I switch to icon view to browse through my clips, which are all shot with TOD t/c they are completely messed up and out of order.
    Anyone experience the same thing and know of a solution.
    TIA,
    Alex Hawkins
    Canberra, Australia
    Zoë Davis replied 11 years, 9 months ago 13 Members · 19 Replies
  • 19 Replies
  • Ann Bens
    July 12, 2011 at 8:55 am
    Icon view has an auto clean up.
    What ever size the icon view is the clips always stay in the same order from legt to right.
  • Alex Hawkins
    July 14, 2011 at 1:57 am
    Sorry Ann I’m not sure what you mean. I know earlier versions of PPro had a clean up button in the project panel, but I am on CS5.5 and that button no longer exists.
    Alex Hawkins
    Canberra, Australia
  • Rupert Howe
    September 3, 2011 at 10:42 pm
    Hi Alex,
    Seems that the only way to sort the initial order is to import the clips into the Bin in Icon View.
    ie arrange the clips in whatever order you want them in Finder (or Explorer I guess, though have only tried on Mac) , then set the Bin to Icon View and drag them in.
    Then you can go back to List View and sort them there in whatever order you want, as it works completely independently. When you go back to Icon View, it will keep the order from time of Import.
    As you noted, if you import them in List View, Premiere will weirdly jumble them up when you switch to Icon View – I’m sure there’s some kind of order to them, but I haven’t looked hard enough to see what it is.
    Bit annoying that there isn’t a manual override, and that if you’ve already started using clips that you’ve imported to a Bin in List View, you’d have to reimport them all to make use of the Icon View properly.
    But this is the workaround, I guess. Hope it helps a little!
    Best,
    Rupert
    Rupert Howe
    Production Workflow Consultant
    Support Partners (UK) Ltd
    https://support-partners.com/
  • Richard Cooper
    June 13, 2012 at 8:57 pm
    I posted this on another thread just now but it applies here as well.
    …. I just figured a quick solution.
    Open the bin in list view so they are in order. Then create another empty bin and set that on into ICON view, then just select all in the original bin and move the clips over into this new bin and they will stay in the correct order. And a bonus… they will maintain this order now even when you go back and forth from icon to list views.
    A Pain for sure, but not as painful as it could be.
    Good Luck!
    Richard Cooper
    FrostLine Productions, LLC
    Anchorage, Alaska
    http://www.frostlineproductions.com
  • Jessie Moore
    June 27, 2012 at 2:20 pm
    You, sir, are the BOMB! That has been driving me crazy! You just saved me a ton of time, and aggravation!
    Thanks for posting your solution.
  • Richard Cooper
    June 30, 2012 at 12:17 am
    Glad to help!
    Richard Cooper
    Anchorage, Alaska
  • Lewis Stiefel
    July 13, 2012 at 6:45 pm
    Ditto….Thanks Richard…starting to migrate from FCP7 to CS6….that is quite annoying…
    seems like something really simple Adobe should address.
  • Patrick Bennett
    August 21, 2012 at 10:07 pm
    This is quite odd. I believe there is a simple sort button/command in just about every other piece of adobe software, why not this one?
  • Jessie Moore
    August 21, 2012 at 10:16 pm
    Sadly, they have not fixed this in CS6 either.
  • Justin Crowell
    October 16, 2013 at 4:25 pm
    Anddddd….apparently no fix in CC. Wonderful.
    Editor, Producer, DP
    JustinCrowell.com
