  • Posted by Snowboarding27 on February 25, 2006 at 5:28 am
    Last year at NAB Apple demo’d how you can use iChat to send out video from FCP to a client with an AOL IM account. Does anyone know how this works and how you set it up. I believe you had to come out of a deck via firewire and then into your machine or maybe a different machine and then assign that firewire input as the video camera for iChat…any thoughts?
    Matt
    Matthew Brunn replied 20 years, 7 months ago 3 Members · 2 Replies
  • Mark Raudonis
    February 25, 2006 at 5:32 am
    matt,
    Yep, you’re right.
    My understanding of this process is that it requires TWO macs to pull it off. One to run FCP and output the timeline via Firewire. The other to run iChat and accept the “timeline” output as the iChat camera. You can’t run FCP and iChat all at the same time. (at least not yet)
    mark
  • Matthew Brunn
    February 25, 2006 at 8:51 am
    You can use one mac but with special circumstances. You need to be using a capture card that has firewire built in. You would output from the capture card and into the Firewire on the Mac and bingo.
    Hope this helps-
    Matthew
    Quad 2.5 G5
    OSX 10.4.X
    Ram 4GB
    FCP 4.5/AE 6.5/DVDSP3
