Activity Forums Apple Final Cut Pro Legacy I want to uninstall fcp5 and reinstall it
  • I want to uninstall fcp5 and reinstall it
    Posted by Eli Mavros on August 18, 2005 at 3:36 am
    There used to be instructions up on Apple’s site on how to completely uninstall fcp…but it seems to be gone now and I need it. Does anyone have the directions or know of another place to find them?
    Eli
    Frederick Moody replied 16 years, 4 months ago 3 Members · 3 Replies
  • Chuck Reti
    August 18, 2005 at 4:44 am
    Apple’s last document 93811 on FCP 4.5 uninstall is no longer on their support site. However, for some odd, prescient reason I had copied it, so
    here’s the info. As noted, it applies to FCP HD (4.5) and other apps in the suite. YMMV with FCP 5. Proceed with caution!
    Final Cut Pro HD: How to Uninstall
    Learn how to uninstall Final Cut Pro HD (4.5).
    The Final Cut Pro HD installer does not include an uninstall option. The folders and files installed during a full installation of Final Cut Pro HD are listed below. To uninstall, delete the following items (some items may not be present depending on what has been installed). Note: You may prefer to access these locations via the Finder’s Go to Folder feature (From the Go menu, choose Go to Folder) and enter the Directory name.
    Location
    File/Folder to Delete
    /Applications
    Cinema Tools
    Compressor
    Final Cut Pro HD
    Final Cut Pro HD Additional Easy Presets
    LiveType
    SoundTrack
    /Applications/Utilities
    Batch Monitor (Note 3)
    Soundtrack Loop Utility (Note 2)
    /Documents
    Soundtrack Loops (Note 2)
    /Library/Application Support
    BorisFX
    Boris FX
    Final Cut Pro System Support
    LiveType
    /Library/Application Support/ProApps
    Components
    Final Cut Pro System ID
    /Library/StartupItems
    Qmaster (Note 3)
    /Library/Frameworks
    AECore.framework
    Compressor.framework
    MediaServerAPI.framework
    Qmaster.framework (Note 3)
    /Library/Bundles
    StompTranscoderX.bundle (if present)
    /Library/QuickTime
    FCP Uncompressed 422.component
    DesktopVideoOut.component
    DVCPROHDCodec.component
    DVCPROHDMuxer.component
    DVCPROHDVideoDigitizer.component
    DVCPROHDVideoOutput.component
    DVCPROHDVideoOutputClock.component
    DVCPROHDVideoOutputCodec.component
    LiveType.component
    /Library/Receipts
    Boris.pkg
    CinemaTools.pkg
    CinemaToolsUpdate1.2.pkg
    Compressor.pkg
    CompressorUpdate1.2.pkg (3)
    FinalCutProHD4.5.pkg
    FinalCutProHDUpdate4.5.pkg
    Helium.pkg
    LiveType.pkg
    LiveTypeSupport.pkg
    LiveTypeData1.pkg
    LiveTypeData2.pkg
    LiveTypeUpdate1.2.pkg
    ProAppRuntime.pkg
    ProRuntime.pkg
    ProVideoCodecs.pkg
    Soundtrack.pkg (Note 2)
    SoundtrackUpdate1.2.pkg (Note 2)
    QTProMedia.pkg
    QuickTimeMPEG2.pkg (Note 1)
    QuickTimeProMediaComponent.pkg
    /Library/Audio/Plug-Ins/HAL
    DVCPROHDAudio.plugin
    /System/Library/PrivateFrameworks
    Helium.framework
    LiveType.framework
    ~/Library/Preferences *
    Final Cut Pro User Data
    com.apple.FinalCutPro.plist
    ~/Library/Application Support *
    Compressor
    /System/Library/QuickTime/
    QuickTimeProMedia.component
    * Tip: The tilde “~” refers to your Home directory. For more information see technical document 106167 “Mac OS X: Using Your Home Directory”.
    Notes
    1. Only if QuickTime MPEG 2 wasn’t installed separately.
    2. Only if Soundtrack wasn’t installed separately.
    3. Only if Compressor isn’t installed as part of DVD Studio Pro.
    Related documents
    107005 “Mac OS X 10.2: How to Find Items on the Hard Disk”
    106237 “Mac OS X: Unable to Delete, Unlock, Modify, or Copy an Item”
    REMOVED FROM SITE >> 93150 “Final Cut Pro 4: How to Uninstall”
    Article ID: 93811 Date Created: May 04, 2004 Date Modified: June 23, 2004
  • Eli Mavros
    August 18, 2005 at 3:52 pm
    Thanks a lot. I hope it works with FCP 5
  • Frederick Moody
    April 24, 2010 at 5:33 pm
    I have been editing with FCP hd 4.5. Just had a MAC specialist upgrade OS from 10.3.6 to 10.3.9 and QT from 6.5.2 to 7.5 in order to read MPEG-4 video files. Now FCP Application will not come up — gives message, “The application FCP has unexpectedly quit.” Do I need to uninstall and reinstall FCP?
