Activity Forums DaVinci Resolve I want to select “Render All Clips” in Deliver page (Resolve 9)
  • I want to select “Render All Clips” in Deliver page (Resolve 9)
    Posted by Michael Holmes on August 24, 2012 at 7:31 pm
    I am using the latest version of Resolve 9 Lite.
    I want to render all clips in one rendering, including all versions of all clips, so that I can then export XML back to FCP X. I am using Commercial workflow so that I can render all grade versions.
    I am attempting to select “Render All” in the Deliver page.
    On Page 576 in the manual it says:
    To render the entire timeline, right-click any clip in the Mini-Timeline (above the thumbnail Timeline) and choose render All.
    An orange bar appears in the Timeline ruler over every clip in the session, indicating the entire session will be rendered.
    When I right click in what I think is the Mini-Timeline (the grey bar under the ruler, with “V1” to the left, above the Thumbnail Timeline), I get three options: Mark In, Mark Out, and Select All. I don’t get an option of Render All.
    Also, when I select “Select All”, the grey bars do not all turn orange. One segment is orange, for the selected clip only. So, it is not clear to me that I have in fact selected all.
    If I right click on a thumbnail in the Thumbnail Timeline below, I get the option to “Render this clip” but no option to “Render all clips”.
    I am doing something wrong.
    What do I need to do to select “Render All”?
    Kendra Okereke replied 12 years, 4 months ago 7 Members · 25 Replies
  • 25 Replies
  • Dwaine Maggart
    August 24, 2012 at 9:39 pm
    Select all will select all the clips in the timeline for rendering. You can verify that by looking at the In and Out timecode values.
    Dwaine Maggart
    Blackmagic Design DaVinci Support
  • Dmitry Kitsov
    August 24, 2012 at 10:22 pm
    Is this a new convention that when all are selected there is no orange/brown bar?
    Does it mean that all are selected for render by default?
  • Michael Holmes
    August 24, 2012 at 10:24 pm
    Thanks for the quick response, Dwaine.
    Then the manual is incorrect, and I am doing it correctly?
  • Dwaine Maggart
    August 25, 2012 at 1:09 am
    Yes, the manual in incorrect. Replace Render All with Select All.
    Yes, when you select all, the clips do not all turn orange.
    Dwaine Maggart
  • Michael Holmes
    August 28, 2012 at 7:21 pm
    Dwaine,
    Well, I finally got back to this project, and the “Select All’ didn’t work for me. It rendered one clip twice, for the two versions, but only the one clip (which was the clip highlighted in the Thumbnail Timeline).
    I then tried highlighting all the clips in the Thumbnail Timeline using Shift-Click, but it didn’t work……..only one clip would highlight at a time (bright orange edging).
    I then tried Mark In and Mark Out, and I can’t seem to get this right either. I tried moving a mark to the start of the first clip and selecting mark In, then went to the end of the last clip and selected Mark Out. This didn’t work either…………….somehow it decided to render only two clips: the 2nd and the 13th clips, out of 46 total. I assume I somehow accidentally told it to do this. (??)
    How do I now remove the Mark In/Out marks, and try again?
    What am I doing wrong?
    Also, I am confused by the naming system.
    I selected “Use Source Filename” and “Render each Clip with a Unique Filename”, using commercial workflow. What I got is this:
    For the 2nd clip it rendered above, it was placed in a folder with the name:
    00007800_00018621.
    What is this number? How is it useful to me?
    Inside this folder was this rendered clip:
    V1-0002_00001(fcp1).mov
    Also inside the folder was another folder entitled “Version 2” (I inadvertently selected “Place clips in separate folders”…..I will un-check this). Inside this folder was this rendered clip:
    The name is identical to Version 1 of this clip. Why does it not give Version 2 a unique ID so I can recognize it as Version 2? Will the XML data give the versions different names in FCP X?
  • Michael Holmes
    August 29, 2012 at 2:09 am
    Nobody can help on this?
    Forget the numbering system questions, just please help on telling me how to use Mark In/Out to get all the clips rendered at once.
  • Juan Salvo
    August 29, 2012 at 2:39 am
    Right click on the time line and select “Render All’. I’d recommend checking out the new manual think you’ll find it answers many questing and is quite useful.
    Colorist | Online Editor | Post Super | VFX Artist | BD Author
    https://JuanSalvo.com
  • Michael Holmes
    August 29, 2012 at 2:48 am
    Juan,
    I have spent much time in the manual.
    Please look at previous posts, you can’t select “Render all” in 9, unless you have found the secret method………..if so, please explain it to me.
    I just want to use Mark In/Out, which should work. I just can’t figure out how to (1) remove all markers I have inadvertently placed and (2) place new In and Out markers so I select all of the clips for rendering.
  • Michael Holmes
    August 31, 2012 at 12:52 am
    Here is exactly what is happening:
    (1) In Deliver page, I highlighted 1st clip (In Thumbnail Timeline), right clicked, chose Mark In. I then highlighted last clip, right clicked, chose Mark Out.
    The In/Out showed the correct numbers:
    In: 00:00:00:00
    Out: 03:19:28:03
    Duration: 03:44:52:08 (some multiple versions).
    When I clicked Render, the numbers jumped to:
    In: 00:57:33:12
    Out: 01:02:54:21
    Duration: 00:05:21:10
    And it started rendering the 13th clip only. It completed this and stopped.
    (2) So, I tried a 2nd approach. I added the job again, right clicked in the Mini Timeline, and chose Select All.
    When I hit Render, it said this has already been rendered, do you want to render again? I said yes, and times changed and it again rendered the 13th clip only.
    (3) So I tried a 3rd approach. I highlighted the 2nd clip, right clicked and selected Render This Clip. Times changed to:
    In: 00:00:06:22
    Out: 00:07:37:19
    When I hit Render, times changed again and it again rendered the 13th clip only.
    So, something is telling it to render the 13th clip only, regardless of what I select.
    I don’t see anything on the left side of the page where I could be causing this.
    Can someone please advise what I can do??
  • Juan Salvo
    August 31, 2012 at 3:23 am
    Sounds like you’ve got a job in your queue with in/out set. I would encourage you to check out the new manual it’s pretty helpful on this.
    If you use the X in the job queue to clear out that job first. Then add a new job with the appropriate settings. Make sure you set all of the job tasks the way you want, and then add the job to queue, so that there is only one job in the queue, it should work.
Page 1 of 3
