Activity › Forums › Adobe After Effects › I want to render a transparent video but .avi files are too big
  • I want to render a transparent video but .avi files are too big
    Posted by Jack Wilholt on October 12, 2016 at 4:42 am
    I am trying to render a 2d overlay intro which needs to be transparent. But .avi files are wayyy to big something like 4gb for 10 seconds? Anyone know what to do?
    Jack Wilholt replied 9 years, 11 months ago 3 Members · 9 Replies
  • 9 Replies
  • Roei Tzoref
    October 12, 2016 at 8:09 am
    If your video is intended for further editing – us QT Png RGB+Alpha. It will be much smaller. Where is this video going?
    Roei Tzoref
    After Effects Artist & Instructor
    ♫ Ae Blues Tutorials
  • Walter Soyka
    October 12, 2016 at 4:54 pm
    What format you should use really depends on what you have and what you need to do with it. What is the next application that you will use this output with?
    Here’s a quick list of common wrapper/codec combinations that support alpha:
    Quicktime, Animation codec
    Quicktime, Cineform codec
    Quicktime, PNG codec
    Quicktime, ProRes 4444
    Quicktime or MXF, DNxHD or DNxHR codecs
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Roei Tzoref
    October 12, 2016 at 4:58 pm
    also Quicktime, Jpeg 2000 and I think that’s about it…
    Roei Tzoref
  • Jack Wilholt
    October 13, 2016 at 10:46 am
    I want to use in it in premiere pro, so what file should I do it in? It also has music so pngs aren’t really a option I guess.
    https://www.youtube.com/c/Peacemaker202MC
  • Roei Tzoref
    October 13, 2016 at 11:07 am
    [Jack Wilholt] “It also has music so pngs aren’t really a option I guess.”
    any of the codecs specified will do. my personal favorites are QT Animation or PNG. Animation – render much faster, but produce a big size file. PNG – render much slower, but will produce a small file size.
    Roei Tzoref
  • Walter Soyka
    October 13, 2016 at 1:01 pm
    [Jack Wilholt] “I want to use in it in premiere pro, so what file should I do it in? It also has music so pngs aren’t really a option I guess.”
    Rendering Quicktime with the PNG codec creates a MOV container for both video and audio, and it uses PNG compression for each video frame. This is separate from a PNG image sequence, which would write one individual PNG file for each frame of video and would require separate audio, as you note.
    I really like the Cineform codec for intermediates between Ae and Pr. It’s a lightly-compressed format, kind of like ProRes on the Mac platform, and is a very good general-purpose codec.
    Walter Soyka
  • Walter Soyka
    October 13, 2016 at 1:03 pm
    [Roei Tzoref] “Animation – render much faster, but produce a big size file. PNG – render much slower, but will produce a small file size.”
    Animation can produce very small file sizes for content that has large areas of flat color — even smaller than PNG sometimes and a lot easier to encode/decode. PNG wins hands-down on size for photographic content, but is very slow to encode as you mention.
    Walter Soyka
  • Roei Tzoref
    October 13, 2016 at 2:17 pm
    [Walter Soyka] “Animation can produce very small file sizes for content that has large areas of flat color — even smaller than PNG sometimes and a lot easier to encode/decode. PNG wins hands-down on size for photographic content, but is very slow to encode as you mention.”
    Thanks Walter. can you give an example where Animation will produce smaller file size than PNG? I did a test right now for a 8sec comp containing only text and solid color.
    Animation = 18 MB
    PNG = 4 MB
    of course PNG took 4x time to render. it’s almost like the time it takes to render, it makes up in size.
    Roei Tzoref
  • Jack Wilholt
    October 13, 2016 at 11:27 pm
    Thank you everyone for your help. I will try all of those options and will reply to this if I need anymore help. ?
