Activity › Forums › Adobe After Effects Expressions › I want to put decimal when reach more than 1000 (1K), how should I put it?
  • I want to put decimal when reach more than 1000 (1K), how should I put it?
    Posted by Edison Kertawijaya on July 10, 2023 at 1:35 pm
    Currently I’m creating expression when reach 1000, it’s become 1K, but I can’t add decimal, currently I need to add 2 decimal behind:
    numSlider= effect(“Slider Control”)(“Slider”).value.toFixed(2);
    if(numSlider>999 && numSlider<1000000){
    n = numSlider/1000;
    Math.floor(n)+”k”
    else if(numSlider>1000000){
    m = numSlider/1000000;
    Math.floor(m)+”M”
    else(numSlider)
    Filip Vandueren replied 3 years, 2 months ago 3 Members · 3 Replies
  • Dan Ebberts
    July 10, 2023 at 1:46 pm
    Try this:
    numSlider= effect("Slider Control")("Slider").value.toFixed(2);
    numSlider.replace(/\B(?=(\d{3})+(?!\d))/g,",");
    Edit: Sorry – I misread the question–for some reason I thought you wanted to add commas to large numbers.
    Maybe like this?
    n = effect("Slider Control")("Slider").value;
    if (n >= 1000000){
    Math.floor(n/1000000) + n.toFixed(2).substr(-3) + "M";
    }else{
    Math.floor(n/1000) + n.toFixed(2).substr(-3) + "K"
  • Dan Ebberts
    July 10, 2023 at 2:20 pm
    Still not quite right. Should be closer:
    if (n >= 1000000){
    }else if (n >= 1000){
    Math.floor(n/1000) + n.toFixed(2).substr(-3) + "k"
    }else{
    n.toFixed(2);
  • Filip Vandueren
    July 11, 2023 at 9:38 am
    I would leverage Javascript’s own method for formatting numbers like this:
    numSlider= effect("Slider Control")("Slider").value;
    new Intl.NumberFormat('en-US', {notation: 'compact', maximumFractionDigits: 2}).format(numSlider);
    A possible downside is that it uses rounding and not floor, so 1599 is 1.6K and 1609 is 1.61K
    The positive thing is that it automatically does K, M, B, T and if you select a different language/region, it will use the correct for that region.
    For example use ‘ms’ instead of ‘en-US’ and it will be K, J, B, T for Malaysian ‘juta’
    use ‘fr-FR’ and you’ll get k M Md Bn (the French convention) but use ‘fr-CA’ and you get k M G T (the Canadian convention)
