Activity Forums Adobe After Effects I want to project an image onto 3D objects if possible.
  • I want to project an image onto 3D objects if possible.
    Posted by Jon Barnes on December 2, 2011 at 9:00 am
    Please forgive me for not knowing what program this would use. Sorry if I’m in the wrong section. First here is an example of what i would like to create:
    I’m tying to make a video where i move from the distorted image(left) to the image that basically looks normal(right). I would assume it would involve 3d tracking of the footage and somehow projecting it onto 3d objects that match the scene(or maybe even without 3d objects?). Any help would be greatly appreciated!!
    Thanks in advance!
    Jon
    Alberto Fernandez replied 14 years, 8 months ago 4 Members · 3 Replies
  • Kevin Camp
    December 2, 2011 at 3:31 pm
    you might look into projection software like madmapper. it handles the distortion (or correction) of the image at the projection stage rather than the creation stage.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Raine Vivian
    December 6, 2011 at 2:29 am
    I’ve done similar effects with project by cutting the video into different layers via masking, and using the corner pin tool to distort it. Takes a little while, but works well.
    -Raine Vivian
    http://www.rainevivian.net
    http://www.seaboundesign.com
  • Alberto Fernandez
    December 16, 2011 at 4:24 pm
    HI;
    You can Do it with After Effect, and any Editor. In my case I used Power Director. check it out:
    https://youtu.be/E2kdB0uWxAY
    this is my house decoration for Xmas this year.
    let me know if you need more details;
