I want to drop Premiere but….
Hi Group
I really wanna drop Premiere and go over to Vegas Pro 8 but I have a few questions before I do
Can Vegas Pro 8 send over its timeline with its effects etc to DVD Architect 4.5 so that you only need to render once?
Here’s what I’m after. I want to cut my project and render it out for DVD only once. None of this render to avi first then to mpeg2 business. I do, however, want to build my own custom DVD menu.
If Vegas pro 8 cant send over its timeline to Architect , will it let me render to a mpeg2, give me control over the bit rate settings? and/or tell me if the final size will fit into single layer DVD?
I’ve used Vegas 6 and I remember you could render your timeline as an mpeg2 but there was no control over that mpeg bit rate settings. It just used its default template but sometimes, I anyway, would want to reduce the quality a little to get as much as possible on a DVD.
Thanks in advance you guys
Vic
