Activity Forums Adobe InDesign I want to design a booklet in InDesign CS5, and save it as a PDF.
  • I want to design a booklet in InDesign CS5, and save it as a PDF.
    Posted by Sebastian Knight on March 29, 2011 at 1:29 pm
    I understand I can create a document in InDesign CS5, like a normal document. Then I understand there is a way to have InDesign CS5 create a booklet, I want to know how can I make it into a PDF?
    As always thanks in advance for your reply,
    Sebastian
    Thank You in advance for taking the time to read and reply to my Post.
    Sebastian
    Sebastian Knight replied 15 years, 3 months ago 3 Members · 3 Replies
  • Terry Mikkelsen
    April 1, 2011 at 5:24 pm
    I use CS3, so I can’t say if there might be a more elegant way to do this in version 5.
    But… I would use the “print booklet” command found in the file menu. Then instead of printing to an actual printer, I would print to the Adobe pdf printer or to postscript.
    Tech-T Productions
    http://www.technical-t.com
  • Xavier Khonje
    April 7, 2011 at 8:21 am
    Actually thats the only I know, too
    If you can imagine it, then you can do it
  • Sebastian Knight
    April 10, 2011 at 11:59 am
    I am creating a 3 page, 2 sided 11″ x 17″ booklet, do I create the InDesign document with the 6 11″ x 17″ pages and the use the “print booklet” command in the file menu to create the booklet?
    Thanks in advance for your reply,
    Sebastian
    Sebastian
