Activity Forums Adobe After Effects I want the TV switch off effect to leave a green background
  • I want the TV switch off effect to leave a green background
    Posted by Bobby Sifon on March 31, 2022 at 2:23 pm
    Alright guys first of all I want so say thanks for the help so far on how my project is going
    https://files.fm/f/zpm9jf2bs
    [image link of project above] At the end of the animation where a tv switch off effect occurs, the logo screen presses inwards to create a TV switch off effect but I want the stationary background to be the same green color it started with at the beginning of the logo not black.
    When the logo screen presses inward, I want it to leave behind the same green that was from the beginning
    see project file link below
    Mads Nybo jørgensen
    replied 4 years, 5 months ago
    2 Members · 3 Replies
    March 31, 2022 at 2:34 pm
    Hey Bobby,
    Just looked at your still.
    Could you not just put a green PSD file on the bottom layer or change background colour, and then key out the black?
    WARNING: Just thinking out loud, not necessarily from a point of knowledge 🙂
  • Bobby Sifon
    March 31, 2022 at 3:49 pm
    Nope dont use the still as reference
    use the files and see if what you’ve said really works…
    The reason I’m saying that is because i have tried copying the other green screen and pasting it to the bottom which painted the whole thing green….not what I wanted
    You mentioned painting the background green… can you explain how to do it?
    April 1, 2022 at 2:21 am
    It might just be me, but your two links are identical and both takes me to the still.
    In any case; in your “Black Solid” composition, you add a layer at the bottom, which you could call “Green Solid”.
    A green solid can be generated inside After Effects, or in Photoshop, or similar.
    If you do that, I would expect your “background” to light up Green.
