Activity › Forums › Blackmagic Design › I used to be able to make DPX files w/ FrameLink. Now I can’t.
  • I used to be able to make DPX files w/ FrameLink. Now I can’t.
    Posted by Ian Dillon on May 10, 2006 at 9:29 pm
    I used to be able to make DPX files w/ FrameLink. Now I can’t. I must be doing something differently and wrong.
    I have a 1920x1080p / 23.98 fps movie that I’m exporting from FCP using Quicktime current settings / Make Movie Self Contained.
    In the past I dropped the new file on Framelink and it created a folder with DPX files automatically, no problem. Now, I have to click create, then designate where to save, then it makes an empty folder and creates a stand alone Quicktime file of just black. No DPX files.
    It seeems like I’m doing everything just like in the past.
    There was an issue in the past where I had to make sure I had “self contained” clicked, but I’m doing that now and still nothing.
    Is there any tips I could try?
    Help!!!
    Thanks in advance!
    Ian
    Kaspar Kallas replied 20 years, 4 months ago 2 Members · 3 Replies
  • Kaspar Kallas
    May 11, 2006 at 3:33 pm
    what codec is the original clip
    only uncompressed and BMD RGB is supported
    -Kaspar
  • Ian Dillon
    May 11, 2006 at 11:20 pm
    I switched to BMD Uncompressed 4:2:2 and it worked.
    By the way, is the RGB way better?
    IAn
  • Kaspar Kallas
    May 12, 2006 at 3:30 am
    It depends on the source
    RGB sources so far are only FIlm scan, Viper, Dalsa, Arri D20, Sony F950, reel stream mod for HVX
    otherwise you are best off in 4:2:2 YUV space
    -Kaspar
