Activity Forums Adobe After Effects I think im a noob – How do i fill a mask with hands (made of masks)?
  • I think im a noob – How do i fill a mask with hands (made of masks)?
    Posted by Tayo Onabule on February 24, 2013 at 6:00 pm
    Hi Everyone, this is my first use of creative cow so please tell me if i make any mistakes.
    Here’s the problem, im making an intro for someone but i cant figure out how to do it.
    The idea is to have a shed load of hands (vectors/masks not images) that when the camera zooms out or the comp is scaled down, the hands make an image. The image i want it to turn into has an alpha channel and i can easily turn it into a mask path in photoshop.
    The question is, how do i fill said image with hands, and enough hands that they’r actually small enough to look like they could be ‘pixels’ in the image.
    I would like it that at the start of the comp/intro, the view is just of one hand, then it zooms out to see hands around it and this theme continue’s till the actual image appears.
    Im almost certainly missing something insanely dumb so please forgive me.
    Thanks in advance
    Vishesh Arora replied 13 years, 6 months ago 2 Members · 9 Replies
  • 9 Replies
  • Vishesh Arora
    February 25, 2013 at 11:11 am
    Tiyour
    What you need to do this is called a Matte.
    Learn about track matte in after efffects
    Check the example file:
    5523_usingmatteinae.zip
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Tayo Onabule
    February 25, 2013 at 7:25 pm
    Thanks so much for your reply,
    I always intended to use alpha matte but i cant figure out how to fill it with thousands of hands so that when zoomed into the image It’s possible see each individual hand that it’s made up of. It’s quite difficult to explain the idea 🙁
  • Vishesh Arora
    February 26, 2013 at 4:42 am
    Tiyour
    Can’t say much about it as the !DEA is in your mind. My advice is to start the Project and then if you stuck somewhere, Post the query and people here will help you to solve it.
    For reference check my example project.
    Vishesh Arora
    Films Rajendra
    Blog:
    2011 3D Demo Reel:
  • Tayo Onabule
    February 26, 2013 at 6:53 pm
    True,
    Iv started and re-started the project a couple of times, the first time i went ahead with Trapecode Form but quickly got halted by 1-2 minute/frame render times.
    i then tried using mosaic tile to tile the hand several times but 1. it still rendered very slowly and 2. i couldn’t randomize the rotation.
    Does anyone know of a way that i can copy a single hand (made of a masked solid) thousands of times to fill another shape? so that i can then zoom in and see the detail of each individual hand?
    i have the Adobe creative suite so photoshop and illustrator are also possibilities maybe?
    P.S thanks for the example project Vishesh.
  • Vishesh Arora
    February 26, 2013 at 8:52 pm
    Tiyour
    You can use Trapcode Particular with a grid Emitter. It can randomize size and Rotation which in your case would help you.
    Choose Sprite as Emiiter and select your hand layer as Texture.
    Check this
    To keep the grid of hands steady, Make sure there the Velocity is set to Zero and there is no Gravity. You can also precompose the particular layer and then use Freeze-Time.
    If you don’t know the basic of Particular then go through these tutorials first:
    Particular Basics
    Vishesh Arora
    Films Rajendra
    Blog:
    2011 3D Demo Reel:
  • Tayo Onabule
    February 26, 2013 at 9:51 pm
    Thanks! great idea, i would never have thought of that, it’d help with transitioning in and out aswell,
    My showreel from 1 year in visual effects: https://www.youtube.com/watch?v=4dv0EaTiVgI
  • Vishesh Arora
    February 26, 2013 at 10:03 pm
    Tiyour
    Give it a shot. If you face any problem then we will try to help you out. And yeah Nice Demo. Great Intros.
    Vishesh Arora
    Films Rajendra
    Blog:
    2011 3D Demo Reel:
  • Tayo Onabule
    February 26, 2013 at 11:55 pm
    Thanks, Your 3D reel was impressive to say the least,
    i tried out that method and it’s working pretty well, thanks for the great advice
  • Vishesh Arora
    February 27, 2013 at 2:25 pm
    Anytime Tiyour!
    Vishesh Arora
    Films Rajendra
    Blog:
    2011 3D Demo Reel:
