Activity Forums Adobe After Effects I started a render, but where is my audio?
  • I started a render, but where is my audio?
    Posted by Milesdavis1 on November 17, 2006 at 6:12 pm
    Hello,
    I’m new to this, any help would be greatly appreciated.
    I rendered a composition, that was based on an imported AVI file w/ audio. I rendered the timeline, and watched the movie and – no audio- was present.
    Do I have to do something different for Audio to render with my movie? I don’t see any indication of it on the timeline.
    thank you so much!
    milesdavis1
    Graham Quince replied 19 years, 9 months ago 2 Members · 1 Reply
  • Graham Quince
    November 20, 2006 at 5:41 pm
    Obvious question, are you sure you had the export audio checkbox ticked. After Effect’s rendering preset for lossless video doesn’t have the audio option ticked. It’s easy enough to change, just click on Lossless and set up your video compression settings and tick that pesky little box.
    If that’s not the case, check you’ve got audio turned on in the timeline. I’ve lost count of the number of times I made that mistake.
    Hope that helps
    Graham
    https://www.quinceweb.com – web design
    https://www.shiveringcactus.bravehost.com – Free FX for amateur films
