Activity › Forums › Adobe After Effects › i saved a file as divx and now i can’i import it back
  • i saved a file as divx and now i can’i import it back
    Posted by Shamway on October 25, 2005 at 12:46 pm
    when i was in school i saved my files as divx from afer effects.
    since than i lost my originals projects.
    now i’m working on my reel and wanted to import those files back into after effects.
    but after effects doesn’t recognize them, i tried to import them to premier, and had no luck there either.
    what can i do?
    thanks
    Shamway replied 20 years, 11 months ago 3 Members · 4 Replies
  • Steve Roberts
    October 25, 2005 at 2:08 pm
    It sounds as if you don’t have the divX codec on your system.
    Sorry I can’t be more helpful, since I never use DivX.
    Steve
  • Shamway
    October 25, 2005 at 2:50 pm
    i believe i have it, since i can watch the file, and did render it from after effect.
    but after effect doesn’t let me import it.
  • Thehardmenpath
    October 25, 2005 at 3:00 pm
    Perhaps you could use another program to convert the divx files into another more AE Friendly format. Even if you could import them, it would cost you A LOT to work with them, as they are designed for viewing them in a linear way.
    You can download Virtualdub at https://www.virtualdub.org/ or other freeware programs that perhaps can open the files.
    Oh, and you should convert them to a format as lossless as possible (virtualdub default, by the way), as your divx versions have probably lost a lot of quality so far, and you surely want to keep them as good looking as possible.
  • Shamway
    October 25, 2005 at 8:07 pm
    Thanks that worked great for me
