Activity › Forums › Adobe Encore DVD › I really need some pointers here?
  • I really need some pointers here?
    Posted by Peter Groom on April 4, 2012 at 7:40 am
    Hi all.
    Im perplexed as I keep getting “build failed” when i try to make a blu ray.
    Ive imported a blu ray compliant Mpeg2 from sorenson squeeze. Its file size is just under 20 gigs, which i think shoul dleave plenty for the audio (ace) and th eauthoring data stuff on my 25 gig Blu ray.
    Ive done the menus, links etc etc and all previews and checks out in the preview tool fine.
    I have over 100 gigs of free space on the drive im using which is an internal sata2.
    The transcode settings on all media are set to Automatic (which i think means it will compress everything down to a sensible size for the disc media available ??? Right ??
    I set the build away onto a new Blu ray, and when i return it says “build failed” but no clue as to why or what i should do to rectify.
    Is it because Ive used a previously used template and changed elements within it.
    If so how can i make a NEW project and import just the chapter menus / buttons data from the old and Ill re map the media etc.
    Any help would be greatly appreciated as this is costing me loads of time Ive not got!
    Hope you can point me in the right direction.
    Cheers
    Peter
    Post Production Dubbing Mixer
    Peter Groom replied 14 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
